STP Oil Treatment
justinray
Contributor
Cleveland, Tx
I had this week off work for a reciprocating compressor class, and found out something that y'all should probably know.. In the industry we are no longer allowed to use STP on anythink that has a bearing or a metal to metal surface. Kinda odd huh? Not once they explained that STP has a relatively high percentage of teflon in it, and teflon prevents metal from absorbing oil. Just a heads up.
Blind Driver2
New Albany, In
No Teflon in STP
Zinc compounds: 10%
Petroleum distillates: 30%
Mineral Oil: 60%
The only thing I would use STP for is drilling or cutting metal on a lathe. Most of those Slick additives have Teflon in it.
MIDNIGHT RIDER
Somebody, maybe me, has been fed some WRONG information.
There is NO TEFLON in STP, at least not in genuine blue-bottle STP.
I have religiously used STP in many applications for years.
It is the absolute best thing to fill your vacuum pump reservoir.
It is also the best choice for oil-bath trailer hubs.
I pre-mix all of my top-off oil with 12% STP; thus, when I have to add a quart to anything, the ZDDP is already in there.
I have always added two 15-ounce bottles at every oil change.
Enough STP and you can almost make good old CI-4 rated oil out of the new CJ-4 crap.
Of course, that is just my own opinion and experience; I have no scientific data to back it up. :)
justinray
Contributor
Cleveland, Tx
I could be wrong, but I do know, or am made to know that there are two types of oil additives, teflon containing and chlorinated. I was also made to believe STP was one of the teflon containing types.
Teflon = PTFE Polytetrafluoroethylene. If PTFE is on the label of contents, it contains Teflon. Politicians are coated with it. Like Slick Willie.
STP® has specially designed products for diesel engines and has labeled them as diesel products. They have been thoroughly tested and evaluated in specific diesel applications to demonstrate their ability to help improve specific performance attributes of those engines and fuels.
Gerhard
