performancelaw
What is the normal temp in the " normal ". Mine is running between the n and o without a load. with a load I'm seeing " m ". What is to hot ?
you guys keep your mouth shut.
Based on his vs. mine we figured my t-stat was sticking open considering the fact that i get absolutley no heat even after driving 20+ miles. what else could be causing me not to get heat. i also have no A/C. don't really care about that though. this winter i will NEED heat.take a point and shoot infrared thermometer and see what your water temps are like at the thermo outlet, inlet to the wp and outlet to the heater. had one truck in the shop the guy changed out his water pump, all hoses, heater core, blend door cable to have heat. Turned out someone shoved a ball bearing in the water fitting in the pass side head... Makes for easier troubleshooting when you know what temp water is where.
