STERLING REAR HUB?????
Clb
Another old truck
nannyfornia
so I get ready to bust loose the rear hub to do brakes and repack the bearings.....
Crack open the book to get the seal pn. *** it shows a puller to remove the hub after using the GAY *** TOOL to remove the spindle nutz. gay
I repeat *** really I hope this is a typo.
thanx in advance cb
did I mention this is gay?
phawk!
Huh?
If it's a 10.25 full floater, you do have to have the hub nut socket, but nothing else special.
It can stick on there a bit. Pry bar and rubber hammer took mine off fairly easily.
Clb
Another old truck
nannyfornia
Thanx guys.
So its just a sticking seal type deal and nut planned engineering stupidly?!
Thats easy
They are packed and oiled according to the manual. Packed when installed and then oil from the diff makes it's way over. I think it's mainly to stop dry starts.
Shawn MacAnanny
Delaware
I'd think oil only would allow them to run cooler. That's weird I've never heard of packed and oiled bearings
Macrobb
North Idaho
Well, I guess this is why they rarely fail, unless you get water into the gear oil...
I have to say that the Sterling 10.25 fully floating rear ends are /really/ easy to work on. Nothing oddball as far as I can tell.
However... Make sure you install a Scotseal rear axle seal instead of the stock 'wiper' seal, especially if you have any pitting or leaking issues.
Use lubriplate 105 lube. Mixes with oil and protects while doing so. I always jack up each side after filling diff just to be sure.
Hey Macrobb, where do you get the Scotseal seals? I have a leaking problem that I can't seem to fix.
This one I think.
I think I got mine from rock auto in a sizable order to spread shipping cost.
