Alright so in chasing down the slack in my steering (and the leak) found that the magority of the slack was coming from the slip joint in the column (between the u-joint by the firewall and the u-joint just above the gearbox). Would a portion from a gasser model work or just diesels (figure it shouldnt matter but just to be sure)? Diffrent generations or just 87-91?
And for the record thinking the leak is either the gearbox or the lines just above it (gearbox is the remainder of the slack now that Ive replaced tie rods) so once funds come avalible both of those will be replaced.
