Macrobb
Try this if you can: Loosen all the injector lines(you may need to remove the top 4 to get access to the bottom ones) and rotate the pump as far as you can to the passenger side. Then reinstall the lines and see how she does.
I've had multiple pumps which ended up 'stuck' in retarded timing mode, which ended up at about 6 degrees off(This is also pretty close to 1 gear tooth). You can get it running better by advancing it by that much, until you get a new IP.
