Look at the wiring harness connector between the engine and chassis. The two large yellow wires in that plug carry battery current to the gp controller. The connector is inadequate for the current and over time will degrade or melt. Be careful as those wires will be 12V+ all the time if you have a good connection. Check the condition of the connector and if it has deteriorated, you can cut the wires out and splice them outside the connector or put a separate plug on them.
http://www.oilburners.net/forums/sh...Battery-connector&highlight=melted+gp+harness
Big red wire on 93 4 gua iirc...
. Ok don't have to tell me twice....
