aaklingler
I just bought the 96 in my sig and its hard starting, I think its slow starting, my best guess is 200-300 rpm. I'm also not sure the gp's are on long enough, I would gues 5-10 sec on first start this morning? The seller told me he has recently replaced the starter and the gp's. I just had the batteries checked and they both pulled 1000s amps and while cranking the volts pulled down to 11.75v The po sounded like the truck has been hard starting since new, he said he plugged it in under 50 degrees.
Also the "water in fuel" light is on all the time. I think I tried draining it, the yellow tab gets turned clockwise 1/4 turn, correct? Nothing comes out.
Also the water temp gauge doesn't work?
Thanks for any help, Allen
