TNBrett
It’s also worth noting that it’s possible for the cold idle speed solenoid to be working, but be adjusted in such a way that it isn’t doing anything.
1) Not sure about the gurgling. To me it’s more of the the truck won’t start the first turn or starts and dies once or twice, then runs fine. That is when I feel I have air intrusion.
2) Was it the o-rings on the fuel lines to the lift pump or the return lines? If return lines they could be leaking again, especially if just the o-rings and not the caps and inter fuel lines. Or it has been 2-3 years ago. Often you can tell because the diesel seeps and makes the area wet ant it starts to collect dust and dirt.
3) I have not looked for Youtube videos, but take a look for both the idle soleniod and IP advance soleniod. You can physically see the idle solenoid, add 12+ and you can see it extend if you move the throttle back out of its way. If it does not move when you add +12v it is not working. I don’t recall if you can see the IP advance working. I have not looked for parts since mine are working but try O’Rielly’s, Ford, and Rock Auto. If not check with some of the IP rebuilders discussed on this site like Russ and Mel.
4) I have bought Motorcraft GP‘s from both O’Riellys and Rock Auto. ~$10 ea.
Let us know how it goes and post some pics.
That’s interesting. Last winter she would sound like a bag of hammers (as someone here put it) which I think is indicative of it working correct? Maybe it either broke over the summer or is mis-adjusted.It’s also worth noting that it’s possible for the cold idle speed solenoid to be working, but be adjusted in such a way that it isn’t doing anything.
Oh right, good point. Well it’s neither idling high nor clanking anymore. I don’t think the high idle has worked since I’ve owned it but the timing advance did last year.That clanky sound is the timing advance coming on, not the high idle solenoid.
Rock
Yes clatter or bag of hammers is good to hear at start up.That’s interesting. Last winter she would sound like a bag of hammers (as someone here put it) which I think is indicative of it working correct? Maybe it either broke over the summer or is mis-adjusted.
