starter ?
LCAM-01XA
my very own hell
I differ in that opinion. mitsu starters are easy to replace components rather than rebuild the whole thing. second, the ND top bolt is a straight up ***** to R&I. third, when the battery voltage drops, the ND will commit thermonuclear meltdown faster than the other two makes.
Hey Calvin, how would I go about identifying whether I have a Delco or a Mitsu starter in my truck?
now that mitsu has come out with a unsupported nosecone bendix, I'm going to be installing that monster on the C6 trucks and see how the ring gear clash is tolerated;Sweet
What is the advantage of this starter, as compared to the regular Mitsu starter with the nose cone bearing?
dyoung14
Is getting worn out
spencer,tn
Mitsu gear reduction- 1st picture
NP gear reduction_ 2nd picture
Delco direct drive - last picture
LCAM-01XA
my very own hell
Alright, well mine has the two long rods holding it together, so it must be a Mitsu starter then. And you guys say that's the best kind, cause it lasts when batteries get low? I can actually attest to that, as god knows how many times that has happened to me, yet the starter still keeps on spinning.
when you get a truck with a worn ring gear, the supported bendix starters tend to clash with the ring gear easier.
the ND starter has a better tolerance to worn ring gears. I'm hoping the new style mitsu will be just as tolerant.;Sweet
david85
Campbell River, B.C.
dyoung14 requested some photos of my starter after seeing my coldstart video. I *think* this is a mitsubishi direct drive starter even though its an AC delco rebuilt. Maybe some one here can identify it.
LCAM-01XA
my very own hell
David, that sure looks like my starter, which according to the pics posted by dyoung14 is a Mitsubishi gear-reduction starter - if you notice the real AC Delco direct-drive starter does not have the two long studs that run along the motor and holding the whole thing together.
david85
Huh, I figured it was direct drive because I remembered it having a strait cylindrical case (other than the outside solenoid) instead of the offset that gear reduction starters usually have. Does it use a planetary geartrain?
dyoung14
Is getting worn out
spencer,tn
Thats the same starter thats on my step fathers PSD:confused::dunno
that's the new style mitsu I've been talking about. there supposedly is a count difference in the bendix drive teeth that makes them incompatible with the IDI. here's the kicker, my alt/starter guy has been supplying me with the open nose starter for problem trucks. he may/may not be doing something special to it. i will have to check with him.
david85
Funny thing is the other starter I had before this would often fail to catch once in a while making a horrible grinding noise during a hot engine restart (usually it only happened in public!!!!). This one has never failed to grab and crank every time.
The sound took some getting used to since cranking sounds like a japanese engine nowLOL
dyoung14
Is getting worn out
spencer,tn
My mitsu fails to catch sometimescookoo so a psd starter works on an idi i knew i reckonised that sound, it sounds exactly like a psd
trackspeeder
Stone crusher.
North Branford. CT
12 teeth for the PSD. 13 teeth for the IDI.
LCAM-01XA
my very own hell
David, so if I underst=and you correct you have a PSD starter in your truck then? From the looks of them the only difference between the IDI and the PSD ones is the nose section (supported vs. unsupported bendix), and apparently tooth count on the bendix gear. Also if trackspeeder is correct (which he probably is) then the smaller number of teeth on the PSD starter would make for more of a gear reduction with respect to the flexplate, which would theoretically make for less load on the starter and easier cranking... Does anyone see a flaw in this thought?
Bo17
