starter problems ???
briang
vestal ny
92 f350 7.3 cc
when i turn the key the wts lite comes on
i can hear the glow plugs cycling, i have lites and volt meter reads fine
when i turn the key, i have to slam the clutch down to the floor for it to start
i have to put all my weight into the clutch for the truck to start
not enough weight on the clutch, nothing, like the starter is not engaging, it act like the truck is dead
but slam clutch to the floor and starts fine
po says its been like that for a long time, is there a sensor that is failing, starter wire, he says there is a piece the cluth pedal engages that broke and he had welded, it fixed it for a while, but it must have broke again i guess or is he full of beans???
your guys input would be much appreciated thanks
dagreendeville
eustis, fl
sounds like the cutch safety switch is bad so your sayin it wont turn over till you slam the clutch pedal down correct?
dagreendeville
eustis, fl
i by passed mine although if you do this you have to remember it will start in gear without the clutch being pressed
briang
vestal ny
that could cause some problems
are they easy to change, and are they expensive?
wife cant start the truck
dagreendeville
eustis, fl
there is a switch under the dash that the clutch pedal enguages when it is pressed all the way daown it either should be replaced or the two wires shall be cut and butt connected together thus bypassing the switch i cannot tell you where its exactly at or the color of the wires because its been awhile since i been under my dash just make sure your not touching the switch on the brake pedal
briang
vestal ny
cool thanks
it is all the work inside the cab
or do i need to get into the engine compartment
thanks again
ADV
Wisconsin
its all in the cab under the dash. the switch is attached to the clutch pedal push rod. I am going to bypass mine with a switch so i can disable my truck so it wont start. Just remember if you bypass it the cruse control will not turn off with the clutch
briang
vestal ny
i found it
looks like you just remove rod and unplug?
i will try to fix this weekend if we dont get to much snow
thanks again guys
ADV
Wisconsin
I do not think you have to remove the rod but its been a while since I took one apart.
