goehill
A friend of mine has a 1999 dodge one ton dullie with automatic trans. the problem is after it runs for a while it will stall. If you wait for about one minute it will restart and run fine for about 5 minutes then die again , wait one minute and go again. We have tried to replace the fuel filter , and still the same. I was going to check fuel preasure, but he went ahead and replaced the lift pump before I could check, and still the same problem. I havent had much of a chance to look it over , but any suggestions?
