speedo problems
93cc7.3
needs turbo power
plainfield IN
Hello again a nedw problem has arrised I lost my alternator last night finished driving home but lost gauges and all eletricial well got new alt charged battery and got it running but my speedo is stuck at the right side pegged it didn't reset anyway to fix this sorry for the messy post doing this from my droid
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Your speed sensor is located on the top of your rear differetial if the truck we are talking about is the 93 you have in your sig. Wonder if unpluging the harness from the sensor and cycling the key a few times would bring it back down to 0. Don't know for sure, just a thought.
93cc7.3
needs turbo power
plainfield IN
Fixed reset speedo memory fuse drove up to 30 mph and it reset thanks for insight
Thats some good information I didn't know about. Now to store that in my tiny brain cell package somewhere......:dunno Usually I have to forget something so I have room for something new....:D
Revelstoke
Spokane/Wa
Hey,
Any-one have theirs just kind of float? Mine goes up to 70, but is usually just kind of floats, and it's off 5 mph. ???
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Hey,
Mine was floating about 3-4 miles per hour when holding a steady spead. replaced the speed sensor and no more floating.
Revelstoke
Spokane/Wa
OK, bone head question:
My truck is an 88 F250 IDI: is it the same as later trucks? Location of speed sensor? Still on the rear Dif? Or is it in the tranny .
Thanks,
Revelstoke
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Thanks,
Revelstoke
I believe it is still on the top of the rear differential but can't swear to it........
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Nope... and 88 it would be in the tailhousing of the transmission... the sensor in the rear diff is for the RABS..... it is the later models, OBS I believe that used only the sensor in the rear diff....
On the 88 rig the speed senser in on the tailshaft housing and its at the end of the speedo cable just before it enters the trans. It has a wire plug in it for the power feed. I took mine apart and found it to be kinda like a motor inside. It had a spinning rotor just like an electric motor. Mine was worn so that the bushings gave out long ago. New one installed and that issue was fied easy. Use some die electric grease so the plug connecter says nice and clean... Lots of road salts and water splashing around under there...
rhkcommander
Oregon
Just found my speedo cable today while trying to figure out where the heck my non-stock tach runs to...
