Sourcing Alternator Pulley
Robt.Webster
Santa Fe, NM
Does anyone know where I might source an alternafor pulley for a '92 F350 7.3 with V-belt drive? I recently bought a high output alternator and it came with the serpentine pulley. I need the 2-V pulley.
I want to maintain the other alternator as a spare.
Thanks in advance for any assistance.
Robt.Webster
Santa Fe, NM
No, same size, but I was hoping to keep the old one on "hot standby". As I am just recovering from major surgery, I a unable to search and pull one from a recycling yard, so I was hoping to buy one outright.
Trying to use this downtime to complete some light of non-physical work I have been putting off.
Thanks for the reply
I just swapped pulleys when I put my 3G in- do you have a different sized shaft on yours?
chris142
SoCal
I would assume those parts may be used on other cars and trucks. If not I'd check with a local alternator and starter re builder.
dunk
Dunce
NJ
Hot standby? Took me about a minute to swap pulleys a couple weeks ago.
FarmerFrank
Blairsville, Pa
The diesel 2 belt pulley is different, the vacuum pump drive part (the outer V) is slightly smaller inside. If you look at the pulley with out the belts you'll see what I mean
