Can30Diesel
Agassiz BC
Hauled another 570 pounds of scrap steel away! Dropped off the last busted cavalier motor at picky for a credit, and helped push a broken down Dodge pickup over the bridge then out of the way.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Loaded up my 1946 Studebaker and delivered to a happy recipient in Allentown, Pa. Nice ride, some steep roads to climb in the small town of Lenhartsville. I borrowed a nice 7 ton low deck tag trailer, a reminder of how much I need to get mine back in order.
bbjordan
Snow Monkey
Ashern Manitoba
Swapped out two Injection Pumps on the '92 test mule to test them after I pulled them apart and cleaned them. They were gunked up something bad. Both worked. WooHoo! :party:
88beast
pa
yesterday i adjusted my timing and vrv etc still got a few fine adjustments but that pump was way off.
texcl
W. of Cavalier, ND
Installed new injectors and return lines from Russ (aka type 4) his products are the best and my truck purrs like a kitten.
Pulled column and sucky auto brake pedal and vacuum booster in anticipation of a Hydroboost manual trans pedal and modified auto column.
next seat and floor covering to prep for std pan cover
Also LOL the clip has to come off to pull the engine!
smolkin
Stuck inside Mobile
Mobile, AL
Yesterday evening finished up homemade pillar pods. After looking at the outrageous prices for universal ones that would have to be hacked in anyway, I opted to rummage around in the maintenance shop instead. Couple of street elbows and some spray paint later...
(Don't worry, not overheating. Gauges got a bit jostled during install, should zero back out)
Dang man. Those look better than the pillar pods.
Just got done with the paint job, gotta mount the mirrors yet, that's gonna be a job, gotta pull the door trim off, the PO had inside nuts thru a 1/2" hole. Got all the top running lites working, all five where burned out. Next is to install new A code injectors and new return hoses.
Mike-M
Ny
Took my tranny out the other day. Today I started taking out exhaust pieces that need repair or modification. The piece that goes from the driver side header over to the y pipe is rotted out so my turbo doesnt do much now. Also started measuring for a psd downpipe mod.
Can30Diesel
Agassiz BC
Quick scouting trip up the Jones Lake Forest service road to Jones Lake reservoir. The excuse? To see if the road is sane enough for a honda civic! The real reason? Because I wanted to play!
So far I have not driven my rig today but plan to maybe on Monday. Not much going on here this weekend...
tke395
