Freight_Train
Traitor to the brotherhood
Skip problem and still brake issue
Ok,as you all know I got the E back with a dead pump and had it up and running real good with a stock used pump and G codes.Well,I was totally un-satisfied with the lack of power(Uh oh here we go!
) so I stuck the stage 1 injectors and turbo spec pump in.Now I have a dead skip.At idle it is noticable but not hugely bad.At 1000-1800RPM is is pretty bad and you can hear it out of the turbo(down pipe not hooked up....HACK HACK dang she smokes if you frog the go lever!
).But I cracked all the injectors and every one did the same thing.Lost some RPM and the engine stumbled and there was a red trickle
flipa) so there was fuel at the injectors.I checked the timing and it is close enough at 9.0 degrees.
Now on to the brakes.
I am thinking I got a bad Master Cylinder.I took the E to a mechanic to have the brakes pretty much rebuilt.They had to replace every line from midship back plus one wheel cylinder on the back(Bleeder broke off),Passenger side caliper on the front(froze up but they got the drivers side to finally work),and the master cylinder(would lose pressure.Internal bleed off).Now I have brakes but it takes over half a pedal to grab and then I have the stopping distance of an overloaded freight train.The pedal is pretty soft but not spongy and doesn't bleed off.Is there an adjustment for the pedal travel?Did I get a bad MC(WHOO HOOO,Life Time warr deal!).
).But I cracked all the injectors and every one did the same thing.Lost some RPM and the engine stumbled and there was a red trickleNow on to the brakes.
