Fixnstuff
Happy to answer this now.I look forward to the post about your oil choices. What do you use in your IDI?
Sent from my Moto Z (2) using Tapatalk
My R. hand is wrapped in an ice pack so my intention was to make a short reply but as the swelling and pain improved I was eventually able to use both hands so this became a long post. I believe that EVERY BIT of it with all of the details is worth reading for most people who are considering a true Synthetic Oil!
I could hardly believe that I found THIS oil at the extraordinary low price I paid for it. I kept thinking that there must be a mistake somewhere, so I researched every detail over and over again for over two weeks and I can offer a couple of reasons at the end on why the price point is where it is.
NOTICE ALL of the approvals by so many different heavy duty diesel truck & equipment manufacturers in the USA & Europe, including THIS ONE:
MILES SXR FULL SYN 15W 40 also meets the extended drain requirements of Cummins CES 20076, Mack EO-O Premium Plus, and Volvo VDS.
When I get the time, I'll look up those extended oil drain interval tests and approvals and I fully expect them them to be at minimum 15,000 miles (24,140 km) and probably more likely up to 25,000 or 30,000 miles (40,234 - 48,280 km) by just changing filters and doing the recommended oil analyses intervals. '30,000 miles' is a number I remember seeing when reading about approved extended oil drain intervals.
HOWEVER, our IH/Navistar IDI engines by original design & engineering have more blow-by into the crankcase than more modern diesel engine designs so the best oils for our engines should be those with the best ability to hold the increased soot (carbon) and probably other contaminates in suspension. On that note I expect that as newer oils were formulated for newer diesel engine designs, they did not reduce the high detergent and and high particle suspension capabilities of of the oils so as to be backwards compatible with older engine designs and they probably improved those qualities for newer engines rather than reducing them because it is a major consideration for Diesel engine oils.
I'll also be using the microGreen filters that have tested and approved extended filter change interval ratings, filter down to particles greater than 1 micron and less than 2 microns, nominally rated for 2 micron filtration through the patented internal oil bypass filtration system. THAT will help a great deal in removing the suspended soot particles at 2+ micron size and of course the larger those particles are, the more damaging they can be. The ability of the oil to keep soot particles in suspension prevents them from attaching to and building up on the engine parts that are in contact with the oil, so that includes the upper engine and valve train.
I'll personally base my own oil drain interval decision upon one or maybe two oil analyses, the first being long after filter change from the fist to the second filter maybe at 12,000+ miles for the first oil analysis because I trust that the oil will be good for at least that long, with the oil I chose and these filters. I'll be able to get a good idea of how well it's working by just frequently examining the oil on the dipstick from the time I first fill it with this oil. I'll check the color first and the thickness or flow rate of the oil next because suspended soot (and perhaps other contaminates) cause the oil to thicken. That should be easy enough to detect between filter changes and the first filter will be changed somewhat sooner because it will be picking up residual soot/contaminates that are still in the engine after I drain the old oil. However, I am going to use an engine flush product just before I drain the oil conventional oil which will help to remove the residual soot/carbon but I want to make sure that it is compatible with synthetic oil. I'll be mentioning that in a different reply (which should be short) Here you go:
BTW, "FULL SYNTHETIC" in this case truly means formulated from 'synthetic base stocks" not conventional crude oil.
https://mileslubricants.com/product/show/1360
That is more testing & manufacturer's approvals for heavy duty/commercial/industrial diesel truck and industrial engines manufactured in the USA and Europe than every synthetic oil that I have looked at but I was not focusing on all of the approvals during that time. When I saw the typical approvals common to the conventional oils we normally use, Cat, Cummins, Detroit Diesel, Ford, etc., that was enough at the time. MY OBJECTIVE is Extended Oil Drain Intervals while maintaining the best protection so I was primarily looking for that.
NOW look at the Amazon.com listing. This is for (4 each) 5 quart plastic jugs = 20 quarts = 5 gallons:
https://www.amazon.com/dp/B01H6JWST...WTZEQBVD840&pd_rd_w=9aKR7#feature-bullets-btf
NOTE:
Domestic Shipping: Amazon only ships this item within the contiguous 48 United States. Other Sellers on Amazon may ship this item to Alaska, Hawaii and US Territories.
If you are outside of that area, ie: Canada, Alaska, etc. etc. Try the SAME listing, SAME price at Walmart.com https://www.walmart.com/ip/Milesyn-...-5-Quart-Bottle-Pack-of-4/49107865#about-item
OR: Go to the Miles Lubrication website (URL further above) and check their purchase options/distributors, (possibly order direct?)
One Amazon reviewer indicated that he only received 8 quarts of oil. (two gallons). A mistake was made somewhere with that order! Often it's the purchaser who screwed up the order.
To confirm that my order would be correct, I checked UPS Tracking of the shipment and the weight/label of the package shows 37 lbs which is consistent with 20 qts = 5 gallons in 4 plastic jugs of synthetic motor oil.
Furthermore, in the right side column there is a link to 2 other sellers. One of those is directly through Amazon.com and I chose that one for the added confidence and protection that Amazon offers, one being reimbursement for return shipping costs if the product received is not what was listed, ie, quantity.
You can also order this SAME product at the SAME price though Walmart.com and have it shipped to your local store location for pick-up or to your home/street address. Be very careful that you see that option before advancing to complete the order or otherwise it will ship to the default address shown in the last step and in order to change it you may have to cancel and start all over again.
Why would the price be so attractive? This is what I figure: Motor Oil and 'synthetic' in this case is a very very competitive market. Once a consumer chooses a brand and they are are happy with it, they tend to stick with that brand often for their entire lives. You need to bring the consumers' attention to your product to convert them to your product and the best way to get most consumers to look at and buy your product is to feature a LOW price.
If they like and trust your product they are likely to become lifetime customers and recommend it to others. This 'low price' tactic is known as , "Buying up market share" and I believe that Miles Lubricants SHOULD be very successful at doing this. Maybe they have more production capacity than they do customers to buy it and they *NEED* to create more loyal customers. After all it's not a big name multinational corporation with oil drilling rigs and refineries all over the world. THOSE are companies and name brands that they have to compete against in the market place.
Lastly, the company's facilities are located at Farmingdale, Oyster Bay, on Long Island, New York (a suburb of New York City, I think). I am located on the Pacific side of the USA, near Seattle. In contrast to the shipping times shown in the listings, UPS tracking says it the order was ready for UPS pick-up on the same day I ordered it, it was picked up later that day and it will arrive here 7 days after I placed the order. If you are located in the N.E. USA the shipping will likely be quicker.
I think that covers everything I have to say or know about this oil. Thanks for reading it!
