MTKirk
I’m deep into my 6.9 rebuild and have one nagging issue to resolve. What to do about pre-cups. All of my precups are original, unmilled, still show the 84 embossing. They do have small, within the fire ring, acceptable cracking. One cup has a small dent (3/16” long X .003” deep) dent right at the fire ring. My initial reaction was to replace this, and all the precups. I went ahead and ordered eight new cups from Diesel Cast Welding. I compared the new pre-cups to the old and realized that my heads would have to be bored to accept the new, larger precups, they are larger in height (.020”) and diameter (.004). So now I’m am leaning toward reinstalling my old precups, and not resurfacing the heads at all (they are within .003 of being dead flat). My biggest reservation is the dent (see pic). I can’t see any way this could cause a compression leak as the gasket and block are solid from the fire ring to past the outer edge of the precup. A careful autopsy shows a punch through in the gasket where this dent is, I’m thinking it is the result of a piece of metal trapped under the head gasket at a previous gasket change, and that it had been this way for a fairly long time. Can anyone think of a reason using this dented precup would be a problem?
