FiredudeL4
Have an issue going here looking for some help, got a 96 F-250 7.3 with the E4OD, tranny was rebuilt about 5 yrs ago due to T.C. going out, had heaver T.C. put in along with a shift kit, fast forward to now. Here about a mounth ago it started shifting REAL HARD from 3rd to 4th, it is not constant but from what I can tell it seems to do it more, the more I drive it, (fluid getting warmer) as I have also noticed that the tranny temp is running alittle hoter than normal, I did change the fluid and filter about a mth ago, as I do it every yr anyway. The hard shift is only from 3-4 all the others seem ok, I took it to a friend of my dads who has his own tranny shop, the first time he said he removed the V.B. and cleaned everthing good and that one of the valves? had a small burr on it which he polished off, it ran ok for a few days after that but then started doing it again, took it back he remove one of the springs (from shift kit i guess) same thing ran ok for a day or so, and is now back to doing it, any ideas on where to go next? thanks
Roy
Roy
