hawaiian808
Whiplash FTW
Hey!
i have been lurking as usual
few questions
can we shave our pistons safely?
and by how much? what is a good compression ratio for 15/20 psi? that i will still be able to start in the dead of winter? and allow me to in theroy run 25 psi? now im am by no means looking to have a great start up just be able to start XD
also the hx35 i tried to follow that thread while at work on my phone and that didint work out as planned, i cant "search" with it and i would like to know how to achive 20 psi with it max and still build boost down low? ( not expecting 10 psi off idle by no means )someone suggested changing housings , like i said tried to follow it did not pan out to well. and one final question, whats a good compund set up? just out of curiousity with max boost being 20lbs? and how many cfms' is it for the hx at 20 lbs ? ( i seriously try to goodle these equations and i never can find them, and im a math retard)
as an up date thank u towcat for the offer onthe cab, i ended up telling them to "splice" in a new roof, now i have a brake like on the back of my cab haha, turned out good they will be done tuesday and ill take pictures for you guys to see the amout of work i should have NOT put into my truck
in the next month its off to have the motor rebuilt!! and thank you to that special someone for those injectors!
few questions
