jhenegh
Truck Still Earns its Keep
Alright, I've found some good info on sending units, but I haven't figured out my problem.
My 1994 currently has NO rear tank, but the lines and wires are still there. Unfortunately, my wiring is stumping me. The attached picture is a picture of the plug that I have. It has 4 receptacles, but only two ocntacts are used (sender & ground I assume, IDI style). And the tank sender I got from another IDI also only has two prongs, but they're a much different shape. They're in the ( O O ) arrangement, which I believe was the plug used before the 4 prong ( O O O O ) style.
SO, what plug do I have under my truck? Am I missing a pigtail that goes from here to the tank? And where can I find the correct femael end to plug into the sender if I need to make a pigtail?
Thanks
Thanks
