Geo
Im gettin the lines from the SD also,
the stock SD setup uses the pump on the frame, then to the filter, filter housing is pressurized to 50-60 psi, and returns to the tank from there.
the SD set up feeds the pass side rear of the head and the driver side front.
there is no return from the heads.
hence the reason for the regulated retirn system. me and PSDhokie an some others were of the first to make a regulated return system
it consisted of metal return lines from the front of the pass side head and the rear of the driver side head, going to a regulator then to the tank, the factory return/ regulator was bypassed.
the OBS setup is actually better other than the pump.
What I am think as for a set up on my 96 is get a SD pump, put it on the frame rail, probably where the flex line meets the frame on the dr side,
gotta get a crash switch, although rolling a truck 5 times didnt trip it, so whats the point,
then from the flex line I will probably use a SD feed line to get to the SD fuel bowl. the from the SD fuel bowl I will feed the rear of both heads, and return out the front of the heads to the regulator, then to the tank.
the regulator I have now is also set up to add fuel as the boost come up.
from prior experiance on my SD I was able to make 330 rwhp and be able to drive without loosing fuel so I think the SD pump will work well on the 96.
As for using an aftermarket fuel filter houisng, I was able to get the stock SD from fleabay for $50.00 shipped.
Im a fan of modifying stuff, but I also want to be able to fix it with off the shelf parts.
Nick
