seawalkersee
It needs a turbo...
Run a pair of wires off of that and be sur they have fuses or links in them. From then, branch them off to the gps. One heavy guage per side.
SWS
SWS
The zigzag metal strap acts as a resistor. This thing will get hot during operation, so keep your fingers off of it. The glow plug wires will connect to the "lower" end of the strap at the base, not at the top on the actual relay. The green wire you see already in place there is important. This is one of two points used by the circuit which monitors the difference in voltage thus determining glow plug "on" time. The circuit is balanced for the total amperage draw of 8 working glow plugs. Fewer glow plugs will not cause a sufficient voltage loss across the zigzag resistor, resulting in short cycle times.
ok i figured it out enough to get the GP's to light and start the engine easier, but i'm jumping power from the "key on" stud to the +12V lug and holding it about 8 seconds then taking it off and cranking, what am i missing to make it "self regulate" and cycle????
-Jon
i made up this little diagram, but i dont know if it is correct. if someone could tell me if it is correct, then maybe it will help 6.9poweredscout
