Wow the coolant confusion continues... I am NOT an expert but I think I have digested the information from various experts. DCA4 was developed with the IH cavitation problem in mind and it has a DIFFERENT chemical protection than DCA2. DCA4 can be OVERCHARGED and it MUST be used with low silicate antifreeze. It is not appropriate for aluminum parts which want high silicate. Is DCA4 better than DCA2? I would not say that because I don't know, but they are DIFFERENT chemicals. You decide.
A nice summary (IMHO) from TheDieselStop:
DCA = Fleetguard's short name for their brands of Diesel Coolant Additive.
FW-16 = Ford's brand name for Fleetguard's DCA4.
DCA4. The right stuff. Used by Ford, International, and Cummins in cooling systems on HD diesel engines. Ford calls it Motorcraft FW-16. Most others keep the Fleetguard name and simply call it DCA4.
But, Fleetguard makes the "wrong" kind of DCA too.
DCA2. The wrong stuff. Also known as Pencool. Catcool. Nalcool. DEXcool. And a few others, Used by GM, Caterpillar, Detroit Diesel, and a few others.
DCA4 and DCA2 are completely different chemicals. Although the Penray Company - maker of PenCool and most of the other "cools" - says it is compatible with DCA4, there is no way to test a mix of DCA2 and DCA4. So the simpliest way is to always check what you're buying, and insist on DCA4 or FW-16 and nothing else.
