JPR
Having burnt the running lights part of the head light switch twice, I decided it was time to correct the problem and take the load off the switch.
Looking at the head light switch, the tan /white stripe wire is the power from fuse #4. Tap into this wire for power to to terminal #30 on the relay.
The dark brown wire next to the tan /white goes to the running lights, cut this wire. The switch side will go to #86 on the relay, to activate the relay when the head light switch is turned on. The brown wire going to the lights will connect to #87 on the relay.
Connect a ground wire to #85 on the relay.
The second picture shows a #8 bolt that is holding the relay next to the fuse box. Once painted the screw should not be noticable.
I purchased the Bosh relay with the plug from Parts Express. $2 for the relay and $1.50 for the plug.
If you use this plug, insulate or remove the red lead to #87a. This wire will have power when the light switch is turned off.
