The Warden
MiB Impersonator
Hello!
If any of you remember when I redid my head gaskets and everything in the summer of 2004, as I was buttoning everything back together, I found that my block heater was leaking. I have a very early 6.9l that does not have the reinforced block, so I never used the block heater, and I was broke at the time...so, instead of installing another block heater for the sole purpose of closing up the hole, I put in an expanding rubber plug. I've always understood that these were meant for temporary use, but it held up surprisingly well!
Fast forward 10 years...I drove my truck a couple of weeks ago and noticed that the coolant level was considerably lower...I used a hand-pump tester to pressurize the cooling system, went around looking for leaks, and found this plug dangerously close to popping out
Thanks again Gary for posting a link to cheap replacement block heaters...I ordered one from Fleabay that day, and finally had a chance to pull the rubber plug and install the block heater today. It got too late by the time I was done, so I decided to let it sit overnight and I'll refill the cooling system tomorrow.
For anyone who might be interested, here's what the rubber plug looks like now
