The engine had 127k on it btw.I'm slightly weary of putting synthetics in an older engine these days. I got a smoking deal on 5 quarts of royal purple and a wix filter for my 22re in the crawler. The first snow run I took it on I spun a rod bearing from oil starvation.
Pulled it apart for a rebuild and found the pickup screen was completely covered in carbon chunks and various garbage. But on the bright side the inside of the engine was fawking spotless..The engine had 127k on it btw.
The new engine doesn't even have 160 miles on it in the last couple years so when the oil change is done on it I'll be using mobile1 and another wix filter.![]()
O.K. I gotta ask. I know their might be varied oppinions, but how to the synthetics compare to each other? Royal Purple/Amsoil/Mobile(do they make 15/40)ect.. I run Amsoil right now - very happy. I didn't get a chance to run the auto RX through it last time but will be doing before my next change.
here's my biggest question. How much are you buying it for. i really want a 15w-40 synthetic, but amsoil is the only thing i can find here, and i just can't justify it. I mean i am not foing to let my engine go more than 6k without a change. The Delvac i have been using is cheap and seems to be good stuff, but a synth would be better for cold starts. . . :/
simply a ostrich with its head in the sand...that cheap oil killed the engine, at least it was cheap oil, it was worth it![]()
A buck a quart and three for the filter ended up costing me just under $600. But on the bright side the money I spent was for a cam new clutch, gasket kit and block machine work. The brand new head and rebuild kit were freebies... I get lots of great hook ups, some obviously better than others.![]()
use Amsoil new engine/trans flush instead, if you think you really need to, generally many owners keep up on oil change intervals and many engines are relativly clean enough to switch over to a sinthetic
Javier
