Rotor change Q's
jaed_43725
Need Quad Cab 4x4
Lillington/NC
I am changing my rotors today and may have a few questions. I have one right now actually. Do you need a press to press out the studs or will a hammer and wood work?
ironworker40
NYC Ironworker
nj
A hammer will work. Make sure you get them seated fully when you put them back. It's a good idea to torque lugs a couple of times after you drive it so to make sure you have them seated correctly.
Without a press you can use a hammer to get them out but try to make up a shim under the stud and use the lug nut to pull them deeply into the rotors. You can't imagine the pressure we can make on a screw thread. As posted, tightening them up in a few miles will save the wheels if any are loose. Once a wheel is loose and wears the rim its usually a ruined rim.
dunk
Dunce
NJ
I use a 4 lb matter to remove and then press them in. They come out easily enough but it takes a lot of force to get them fully seated. Would not advise pulling them in with the nuts, can mess up the threads.
jaed_43725
Need Quad Cab 4x4
Lillington/NC
Thanks for the advice on putting them back in. I wish I had a press. Perhaps a shop could do it for a small fee.
homelessduck
I use an air hammer. Takes less than a minute. Easy peasy.
lewisstevey7
