rim question
ADV
Wisconsin
Will rims and lugnuts off of a 3/4 ton dodge work on our trucks?
lindstromjd
Black Sheep
West Des Moines, IA
Those will fit. The thing to look for is how big the hole is inside the lugs. 2wd wheels have smaller openings. If it helps you feel better though, you can always take your truck over to his house and test fit one on your rear axle.
ADV
Wisconsin
Seller just told me tires are sold but he still has the rims. Still thinking of picking them up they look better than my rusty black ones.
Not to hijack but will GM wheels fit? I know where a pile of 8 lug chevy rims are. I'm looking for a spare. I'm pretty sure the patterns the same but same deal, I'm not sure about the center hole size.
887.3DirtyD
Lancaster,OH
I think up until 2001 will fit, but remember, gm has smaller hubs. I can't remember exactly when they started that.
GM 8 on 6.5 have different hub pilot diamter
Older Ford Dodge have same hub Pilot diameter but GM was smaller...typical light duty chev buwa ha ha ..
When Ford went to the 10.25 rear diff that hub pilot diameter changed ...increase and NO I don't know size...but I do know GM WON"T fit... newer dodge may fit I cannot speak to this on experience...
All have same 8 x 6.5" bolt circle and Ford went to 8 x 170mm Bolt circle in late 90's IIRC but not 100% on date..
Bottom line test fit the hub fitting over your rear axles hub and fitting correctly...if not..don't buy...
Hope this helps
Al
Poway, CA
FWIW, there's a guy on FTE selling a set of Alcoas for $265 shipped, with caps. They're painted, but could be polished up pretty easy.
Mike
BDOGONE
florida
Dodge 2012 on 94 E350. 8 on 6.5"
Center hub size is too small and needs expanding by 1/4"
Ford has largest hub, Dodge smaller and GM has the smallest hub. (Factory rims)
After market rims all use large center (not hub centric) any 8 on 6 1/2 will interchange.
Later Ford P/S use 8 on 170mm, vans never changed, and Ford even used a 7 lug in year supposedly. About as rare as Bigfoot sighting I guess?
Here's my "redneck" milling machine for hub work.
Sent by wing, prayer & ATT
BDOGONE
florida
I think I'd buy as seven lug, mount it on the wall " Fords better idea". Lol
