Rigid HPX line....
geonc
SPIDER BAIT
NECKVILLE North Carolina
Having seen the flex lines from Dale Isley and others and taking into consideration my recent HP line failure :eek: -cuss I recall seeing HPx lines in rigid tubing......just can't remember where :confused:
Any clues?
94f450sd
somewhere,ma
have you tried contacting ryan at BDP?
you may not want a rigid line as the vibrations may cause it to crack at the fittings unless you can find a way to bolt it to something solid in the middle of the line.
Mike
Stroker
Cora
I dont recall seeing a rigid HPX, but have often considered making one. Only reason I havent is for what Rich mentioned. Always been afraid it would crack. Let us know if you come up with something geo.
clux
KCM diesel builds them for ITP, and usually sells them cheaper, that's where I got mine.
http://members.***.net/kcmdieselperformance/ford.htm
94f450sd
somewhere,ma
i would not run that line on my truck do to the fact that it is too long and has nothing supporting it anywhere.it would be like the IDI engines that dont have the vibration clamps on all the lines,it will eventually crack and spew oil everywhere.
clux
It's really only about 12" across, shorter than some of the stock fuel lines, and pretty well supported by the ORB fittings. I've never heard of anyone having one break, while I have heard of a number of the flexible cross over lines breaking and loosing oil.
geonc
SPIDER BAIT
I just had a factory HPOP line burst a couple weeks back -cuss ....what a vulcan mess:mad:
If memory serves , doesn't the bigger HPOP's --stealth/dual etc... use the same type rigid line?
Not the same length obviously :D
94f450sd
somewhere,ma
looks to be a bit longer then 12".also remember that every bend is a weak spot and it has 2 bends in one spot.
94f450sd
somewhere,ma
yes the stealth runs a steel line but its short,looks to be less than half the length of the line in the picture
clux
Yes, the pictures are decieving, but I have one and it's just about a foot. You can measure across the engine valley at the ports in the heads, it's just over 12".
jchellen2
