reverse lights
69oiler
I don't feel tardy
Chardon OH
where is the switch for the reverse lights on a C6? mine have not worked since the tranny swap.
sassyrel
iowa
and the neutral safety switch should be somewhere on the side of the trans--two wires out of it--at least they used to be--and that harness connected to another on the firewall----with a matching mating plug.
Correct. There is like 4 or 5 wires coming out of it, and it is on the shaft that rotates when you select your gear.
