Return Line Kit
geno8769
Southeast Louisiana
Working on my "new" truck..
Any suggestions on who to buy a injector reurn line kit from?
Oregon Diesel?
Thanks
motox tech
granby, co
ebay,but beware, the cheap ones are inticing but are exactly that. I just put some on my 94 and all strait through caps were leaking like crazy!!! The hose, o-rings, and washers were fine, but the caps were way too sloppy. Ended up using 4 old ones, and not a leak.
Typ4 will give the best deal.. Stay away from Diesel Care. The reasons are found in the Hall of Shame section. Many members have been less than happy with anything they buy from them....
zpd307
Zumbrota, MN
maybe that was my problem. i got the cheapest kit off of ebay when i did mine and have had nothing but leaks. the caps were really loose after they were pushed on with a click. i ended up putting a washer between the oring cap and injector line nut when i installed the new ip. so far no leaks, and she starts right away, even after sitting for a couple of days.....
typ4
Newberg,OR
The trick is to use an extra oring on top of the cap to keep it from vibrating. Also some of the caps have a burr inside because of poor manufacturing, light sanding fixes it easy. Seems to be a not made in the US problem. If you know what I mean
Bill-W
GA
I just did mine last week for the first time, it still had the originals. Got the kit from Diesel Care. They fit good with no leaks, only issue was I needed to re use 2 clamps as my lines tie into the return to the tank, there were only 16 Clamps. Be sure you get a good dental pick to grab the old O-Rings with.
Truck#3
WA
I got mine from oregon diesel. its a great kit comes with everthing even copper washers for the injectors. i had no problesms
russ-
the old diapco kits were coming out of Italy......
