Replacing ZF5 clutch/ flywheel problems/ emergency.
direwulf23
Botkingburg (NCen), AR
Okay, I have one more day to get my clutch/ flywheel replaced. Transmission is out.
I can't get the clutch bolts out. Tried two bolts and started to round them off. Tried a 20V cordless impact and no go. Tried again with a 3/8" ratchet that had a 1/4" adapter for the socket and broke the adapter. Can't get those dang bolts loose. Need suggestions!
1995 Ford F250 SCLB 4wd ZF5 7.3L PSD, stock.
worst comes to worst, you have a new fly wheel, right?
if so, cut them f'rs off!
ive always used a 1/2" drive 9/16 socket to get the pressure plate off.
did you PB blaster them?
94f450sd
somewhere,ma
They probably have some loctite on them.get your hands on one of those little burns o matic torches you can get at walmart,auto parts stores and every hardaware store.get the mapp gas cylinder instead of propane.
Just heat the bolts up a little,youre not looking to heat till they turn red hot.make sure youre using 6 point sockets,12 points suck and will round bolts and nuts before you know whats going on.
direwulf23
I started with a 12 pt. and switched to the 6 pt, that's why I had a 1/4" drive socket. My 3/8" socket for that was the 12 pt.
go buy yourself a 6 point 3/8 or 1/2" drive socket.
you need it!!!
direwulf23
Okay. I'll make sure I have it. Going to tear back into her in a little bit. Getting up later cause I'm getting wore out. Lol
direwulf23
Now, I can't get the flywheel bolts off, even with the air impact. Am I missing something or is it a straightforward process?
straight forward, use map gas to burn the loctite out
i put a c-clamp on the fly wheel to keep it from spinning, and a 6 point socket and a breaker bar
ntjapkes
