Does anyone have any ideas on how to separate emulsified oil/water mix from WMO/ATF.?? Will it separate out and layer out over time from the other "good" WMO/ATF.
If not. how can one get the water out ? Centrifuge ? Distiller?
How do you get the antifreeze out ?? I assume it will kill a IP/injectors.
I am looking into running WMO/ATF/Diesel mix in a 1991 Cummins 5.9.
Thanks.
Thanks.
