Removing all the coolant.
Sycostang67
Scooty Puff Junior
Kuna, ID
What's the best way to evacuate all the coolant from the motor? I was changing my water pump and saw my radiator was pretty gross. I took it in to get cleaned and bought 8 gallons of 50/50 fleetguard antifreeze from the cummins shop. They said it already contains the DCA-4 additive. I dont know what was running in the system before so I want it all out. If it matters, the water pump is still on the motor, but the radiator is gone.
dakotajeep
Patrolling
TN/ND
Have you removed the plug from the drivers side rear of the engine?
Sycostang67
Scooty Puff Junior
Kuna, ID
I know nothing of this plug you speak of. Is it a freeze plug or some other kind of removable plug?
It's a brass pipe plug, also one on the passengers side behind the starter. Use a six point socket or six point box end wrench, or you will round off the hex. You will have to blow the heater out to drain it.
Bo17
