vanillavanwinkle
Hey everyone, so I recently finished rebuilding and installing a 1988 7.3idi into my truck. Engine fires up and runs no problem, but as soon as I started pouring coolant in, it went straight to the oil pan. In the maybe 2 minutes I was pouring coolant in, it filled the crank case with the whole 8 gallons of coolant I put in, so it's a pretty quick leak. Before I installed the heads or anything, I filled all the coolant channels with coolant and it didn't lose any over night so I don't think its a block issue. I did swap oil coolers from my old engine because on the first start, it blew out the o-rings. I used the dorman kit just to reseal the heads to block and left the o-rings alone. The only 2 things I can think of would be oil cooler or water pump cavitation. I didn't see any holes in the timing cover, but there was obvious signs of cavitation there. The only things I can think of that would dump that much coolant into the oil that quickly are oil cooler and water pump. Is there anything besides a bad block, heads, cooler, or water pump that could cause this that I may have missed? Or any idea in general as to what it may be? Thanks
Didja get things uncovered yet?
