CheaperJeeper,
I finally got some pics of what I was trying to explain regaring the original Banks mounting of the CDR and routing of the hose to the timing cover. The original Banks mount calls for the CDR to be mounted to the air cleaner with the inlet pointing up. The hose then runs up, over the air inlet and then back down to the timing cover adapter (see Banks instruction sheet). In that orientation when the hot vapour cools and condensers (turns to liquid) it will accumulate in the CDR and once it's half full it just starts to drain into the air cleaner housing. There is no way for it to drain back into the engine.
What I did was cut the hose from the CDR to the timing cover adapter and install a coupling so I could change the orientation of the hose and then mount the CDR with the inlet pointing down so if any vapour cools and condensed it will run out of the CDR, into the hose and eventually back to the timing cover adaptor. It seems to be working quite well and has been like that for at least a couple of years. Just something you might want to try that's cheap and easy.
