Had a bearing fail the other day and iam in the process of replacing all bearings and seals. Probly going to change fluid in the diff. Iam having trouble removing the outer bearing cup. The bearing disintergrated and I was able to pull everything else off. Any suggestions on how the get it off? Also, should i replace anything in the diff while iam in there? Thanks
