Dave Barbieri
I keep hearing about this roll over valve....***...I have pulled a few tanks and I cannot find one on any of the tanks I've pulled....
It looks like that tank would accept the stock skid plate too....hmm...may have to look into this particular tank for my 1ton..
Is it as large or larger capacity as the Bronco tank is my?
Here's one of the roll-over valves that my 85 uses. I understand these changed over the years, so I'm just describing what MINE does. There's a little shuttle inside the body, that can slide up and down. When the valve is upright, air can pass either way, so the valve keeps the tank vented to atmosphere. When the valve is turned upside down, the shuttle slides into place, shutting off all venting both ways. Nothing in, nothing out. My valves were originally routed up to the underside of the bed and capped with a little cover that kept insects/dirt daubers out.
I didn't want to give up the ability to keep the tanks at atmospheric pressure, so I installed a separate vent line and kept the RO's.
As far as capacity goes, it's around 40 gallons. Whether that's 38, 39 or 40, I don't know. It's listed as the tank for an 85/86 F350 with a 460. All I know is that the sucker is BIG and holds enuff fuel to make your wallet gasp.
