SD70Ace
Big yellow Diesels
Im in the process of swapping out rear ends on my 2 one ton trucks. The good rear end,i had to pull the hubs off and pull the drive axles out to get to the parking brake stuff to remove it. When I stabbed back in the axles, I got them pretty close back to where they were before. If Im off some, will I run the risk of shelling out the rear end? I guess its a like a 3.43 or bigger rear end. Aint 100% sure what it is. They look alike.Thats all about all I can about the rear ends. Next what kinda transmission did Ford put in it. C6 or what. The reason for swapping out rear ends the orginal must have shelled out a bearing or something and when it bit the dust. Axle and all came out, tearing up the end of the rear end.
