On My 93 the rear axle yoke has a little play on the Ujoint end of business, the yoke is not worn out nor it allows any oil to leak past it but I installed a new U joint and I can see the U joint moving about 1/16" side to side inside the caps and the old one was doing the same thing. I though maybe I have the wrong U joint but I can't confirm that, I did ask specifically for the rear U joint.
I'm thinking the problem is the Yoke on the rear axle, so if I remove the old yoke to install a new one will I have to re-set th ring and pinion on the axle? I'm not sure if this year came with a crush sleeve. I have a vibration from 67mph and up, I'd like to eliminate this problem just to confirm it is not the cause of it.
Also, where is a good place to get a yoke for the 93 f350 DRW rear axle?
Thanks.
Thanks.
