Rear axle set up
rustygold
conway Arkansas
Well 12-15 is a little lose for me but I would go with 12 at the most just harden them gear before doing drive at different speeds for 30 to 45 mins let cool then they are harden.
Sent from my SAMSUNG-SM-G870A using Tapatalk
rustygold
conway Arkansas
austin92
Brazil. IN
That's how I wanted mine to look, little closer to the toe and a little deeper but everyone I showed said it was a good pattern
1983 f350 6.9 zf5 2wd srw single cab long bed. Facet duralift, optima red tops, bfg all terrains, 4" exhaust from y pipe back, autometer z series pyro, pump turned up 2 flats
rustygold
conway Arkansas
I wish my coast was a little bit more to the toe. But I'm running .010 shim factory came with a .025 shim. I am going from 3.73 to 4.11 I think if I go bigger ir will be no shims.
austin92
Brazil. IN
I used the same shim thickness that came off the factory pinion and it put me dead on. Got lucky. I have a bunch of shims left over, do you want me to see if I have any under .010?
rustygold
conway Arkansas
No it will be fine I'm going to run it like that it's a healthy pattern for drive coast it can be alittle different. I know no shim make it go all the way across might try that and get the back lash right. Working on it late at night make for mistakes when your tried.
austin92
Brazil. IN
What's yours at now?
I found this that shows 11-16 on a 10.25
austin92
Brazil. IN
Anyone know if a 10.25 will bolt in a 75 f250? Buddy was wondering if spring perches and shock mounts were the same width
rustygold
conway Arkansas
What I found says you do but if he was going to make it worth it all. Go with disc brakes it would be awesome.
austin92
Brazil. IN
He already has a drum 8x6.5 10.25. Both him and I wanted a disk 10.5 but the bolt pattern made up our mind for us.
For the record, my truck drug his backwards when we chained them together lol. He's running a 460 c6
austin92
Brazil. IN
I'm ok with that :)
austin92
Brazil. IN
FINALLY making more progress. Loan money ran dry and over time was scarce at work but tonight I placed the order for new inner and outer Timkin wheel bearings and races, national wheel seals and pinion yoke repair sleeve. Also the other can of por 15 I've needed to do the other coat
austin92
Brazil. IN
Got the pinion repair sleeve on, seal installed, and new nut locktited on. Just need shoes, wheel cylinders, and the conversion ujoint and she's ready to go in. Do you guys know if my existing e brake cables will work or should I get a set for the 94 axle?
Lance
