Rattles a ton when starting cold
basilbowman
Sewanee, TN
Just exactly what the title says - maybe 10-15 seconds of real hard rattling before it calms down, and then it steps down from high idle maybe 2 or 3 minutes later. Is that a normal diesel or is my timing off?
basilbowman
Sewanee, TN
Shadetree did it pretty roughly by ear for me in the summer - is that something damn near any shop can do correctly, or is there enough of an art for it to be worth seeking out somebody highly recommended?
basilbowman
Sewanee, TN
Also - I think I've got some air intrusion issues, it doesn't like to start up on the front tank, I think because it'll seep back. I need to chase those down over Christmas Break - does that change engine noise?
Dieselcrawler
Professional wrench holder
Quakertown Pa
acutally it sounds like it is damn close in timing. when the timing is set correctly, and the motor is cold, it will rattle really loud till she warms up a bit
gdhillon
PG...Canada
thats what mine does....along with a large cloud of blue or white smoke
TWeatherford
Flagstaff, AZ
Mine rattles pretty good cold, until the cold advance kicks off. It does it a heck of a lot more since I got a meter from Gary and set the timing to 9* BTDC, so I know its set right. Now I'm used to it and my neighbors can get over it.
Disneyland, CA
Mine was doing the same thing and found the O-Rings at my return caps were leaking. After replacing them it cured the problem. Good Luck
johneich
John, 1983 F250
Southern Illinois
Is that something damn near any shop can do correctly, or is there enough of an art for it to be worth seeking out somebody highly recommended?
I have one of the Kent-Moore meters Gary rents out and I just follow his instructions, its easy
Some shops will "rip you off" and time it by ear for $100.00+
Most shops no longer have the knowledge to do the job properly anymore.
finitetime
Georgia
Air intrusion.
I have set of the cheap return lines and caps and mine rattles a lot more than it use to. If I let it set for more than a day its a B@#*! to start without holding the pedal on the floor for 10 sec.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
I'm definitely loud on startup. Music to my ears.:sly Gets pretty quiet and smooth after warm up though. I'm timed at 8.5deg.
gatorman21218
Ashland VA
yes mine sounds like a chain swinging around in a 55 gallon drum, along with enough blue smoke to kill every mosquito in the south.
once she warms up though its right. I just replaced the IP and injectors last winter, and while I never did time it, its been running good, so I just hold my breath and truck on
basilbowman
Sewanee, TN
I did all the return lines this summer fighting air intrusions then, they're brand new. Maybe it's just the way these IDIs are - it's real loud though. I've got to change the oil in the next couple hundred miles, I think I'll put some 5w-40 in and see if that quiets it down a bit.
basilbowman
Sewanee, TN
I've been informed that air intrusion can cause advances in timing - and since I've got a bit of a leak, which causes a bit of a zoom when it starts up - I'm thinking these are all related. I'll drop it in the shop over Christmas and see what I can find. I hate hunting for airleaks though!!
