radio isnt working properly
guyintx
TEXAS
just wondering if anybody else is having a problem with this. My radio does not pick up local stations very well. just wondering how to fix it. my ant. is tight so i am thinking maybe a wire is loose or something. Any help would be appreciated. Shawn
Whit
lost in Why-homing
Shawn, pull the bezel ring around the radio and this will give you lots of room to look to see if the antenna is plugged in tight to the radio............worth a try anyhow.
Cheers, Kevin
TheWolf
PA
one thing I have noticed is that with every vehicle I have had each one picks up the stations a little differently than the other. Also, some stations come in differently depending on the weather for me.
guyintx
TEXAS
i will try pulling it out his evening and checking the back of it. About the weather if there is any fog whatsoever then it will not pick up any station. thanks for yalls help shawn
haz-mat19
alpharetta,ga
If all else fails you could take it in and have the stealership give it a look. Warrenties are a good thing. See ya
Whit
lost in Why-homing
No need to pull it out, simply pull the bezell and there is a ton of room to check it
holtzer1
missouri
the stock radios suck, we replace them on a daily basis almost...and i wouldnt call it a stealership...the only time you people go there is when you want something ....FOR FREE>>>>>>>>>>give it up already, if you are such a great tech...why arent you fixing ALL the problems on your trucks... cookoo :draw
guyintx
TEXAS
i never said i was a great tech......the only reason i was asking is b/c i was trying to avoid the stealership. :backoff
holtzer1
missouri
aftermarket radio is the way to go then...unless you upped the cash and got the dvd player/navigation/in dash changer/ satalite radio
