R&D idi return rail hose route
@HS108 clued me in that the rails I have were part of a recall Justin did on Facebook
As soon as I took them out of the box I saw the machining was poor, but it is good to see there was a reason. I’ll retract my opinion that these don’t work, because I’m sure the corrected rails work as designed, although I think if you are doing a product recall you should email your clients so everyone knows, not just fb followers.
gerlbaum
AZ
Justin has a how to vid on installing his rails and he says to run a red scotch bright pad in each hole. Might be where most people’s leaks come from
Yup! Haha I'm not clever enough to have thought of it on my own. I think the tolerances are just really tight. I kept tearing up my o rings until I did.
HS108
Diesel Newb
Connecticut
@Thewespaul you gonna send them in?
NP I have a weird memory on stuff sometimes. When you said you were one of the first it made me think about the post.
Someone else sure could, last time I had to get ahold of Justin to ask about some parts a customer bought, it took a lot of leg work for me to get an answer since I don’t have a Facebook, not worth it to me to go through it again for a set of rails.
Studebaker62
