Too late now, but I usually soak all connectors with some kind of knocker-loose several times and several days before beginning such an endeavor.
You can do this with a propane bottle-torch if that is all you have.
Heat a nut until it is as hot as the propane is gonna get it.
Take the flame away and immediately stick a candle against the threads of the bolt, close to the nut.
You can actually see the hot wax creeping into the threads between the bolt and nut.
Somehow hold the bolt from turning and the nut will now come off.
If that fails, then cut the bolts or split the nuts and replace with new ones.
Don't burn down the truck.
