question for Mel GV overdrive
Eason
Williamston/NC/USA
Mel I believe I read somewhere that you adapted a 1356 od unit to your 1345 case. How hard was it to do? Or did you use the 1345 GV unit. Thanks Eason
I did one too.
you will need the back half of a 1356 case.
swap the back halves out.
install the GV adapter on the case.
bolt on GV to the adapter.
install modified driveshaft.
install electrical.
refill with fluids.
take for test drive.
