Question about the pyro for Edge.
Racing41
I just got my Edge Juice with Attitude. I already have the pyro thats on my other gauges. Can I just tap into the wire and hook them up together or do I need to redrill another pyro hole? If I can just wire it in. please inform me on how to do so. Thanks
argve
Resident Fruitcake
Gwynneville, Indiana
You will need to either dedicate the pyro to the gauges or the Juice you can't run both as it will cause bad readings. This is because you will be splitting the current generated by the probe between the gauge head and juice module. So if you want to keep the gauge and run the juice at the same time then you will need to install another probe for the juice.
