zigg
I'm about to do the mod where you put the lockup converter on a switch on the dash.
My plan is to have 2 of them. One will be Auto setting and off, and the other will be on and off only.
The Auto setting is for when anyone else might be driving it, and the off/on is for me only(probably going to hide it or something...
Anyway, what I'd like to know is there anyone that has this mod, and once you flip the torque converter to lockup position, can the tranny still shift while the converter is locked?
An example would be if you were coming down a grade with the lockup on, and then hit the OD button to drop down into 3rd from 4th. Do you have to manually unlock the TC first before making the shift.
Same idea on the upshift. If you were on the hwy at say 45 in 3rd with the TC locked, could you just shift into OD without worrying about the TC?
Thanks
Zigg
Thanks
Zigg
