pyro problem?
blackbear
huntington beach
greetings hellas. i have a 94idit that ive recently swapped out the old mechanical isspro gauges for new isspro electrical gauges(evII). the former owner installed the pyro after the turbo, so i mounted the new one in the drivers side manifold. which is located more towards the second to last cylinder. i did notice about a one inch crack in the manifold too. i didnt use the added wiring for the pyro since i didnt need the extra length and the instructions stated it was not necessary to do so. i linked the power and ground supply separately than the other gauges. so after running the truck it seems to me the pyro lags quite a bit. i havent removed the old thermocouple yet so i reconnected the gauge to compare the two. they both seem to run at the same temps?? idle is close to 250-300*, 55-70mph is running mid 400*s. starting at a full stop and using heavy throttle the post pyro climbs faster and higher than the pre turbo (pre turbo reaching 450*ish and post turbo around 600*). the truck has an inner cooler and ats elbow and dp. do i have a faulty pyro/thermocouple? any help is appreciated! thanks.
longhorn795
damscus va
ive had a problem on my pyro,it is a new autometer,evertime i go to start it up in the mornings and right before i start it its sitting on 100 degrees not on 0,anyone know what could be the problem?
blackbear
huntington beach
Thermocouple, that seems like it right. Ill call isspro tomorrow and see what they say. As far as the gauge starting at 100* instead of 0*, I couldnt say. The gauge I have numerically starts at 100*. Thanks for the compliment '94IDITurbo7.3, I'll have to make time to wash it before I make time for photos.
