03wr250f
I am puzzled by the problems I am having with my truck. I am going to list the problems (not in any order) I have been having. I have done some research on them but I really am lost. I don't want to just keep changing parts until the problem is found, but I do want to get this fixed. thanks in advanced and any helpful input is readily welcome.
When I first noticed problems I made a trip to Denver (2.5 hours both ways) to buy a car. I let my roommate drive my truck, and it was working fine before that, He has a decent head on his shoulders, and would have done anything dumb (I don't think). but then I hopped in my truck and first started noticing these things.
the previous few weeks I had also been noticing my truck would not want to give me full power for awhile, it would just lightly spit and sputter for awhile once driving and after 5 or so minutes it would go away. I always fire my truck up with nothing turned on the slowly turn the heater and radio and other things on. She always gets at least 5 minutes of warm up, typically 10 +. I try to be as nice to her as I can and treat it well. I even drive it carefully once warmed up.
-After 45 MPH the rear antilock light comes on, never has before. I looked into this and people have said lack of vacuum, but when I bought the truck there was a 2'' long hole in the vacuum line, I have since repaired it, and my cruise control is no longer working. the month previous I noticed it was getting it harder to get it to work but just chalked it up to an old truck.
-jittery power for a bout first 5 min of driving
-slight surges until constant speed is reached
-lack of throttle response especially after 55. I get that these may not have new vehicle response but it is probably a second slower to respond than it was before, and less power it seems according to the but dyno, but I may be slightly exaggerating since im looking for things.
I just replaced the oring on the top of the fuel heater and also the fuel filter while I was there. those problems were present before I did the service, and are still present after that. yes I did bleed all the lines and all of that good stuff, but on a side note I apparently didn't get the bolt for the fuel filter heater on tight enough. I need to re tighten it... so does anyone know the correct torque for it.
Thanks for any and all help guys. I am really at a loss so any help is great.
